I changed the shocks on my wifes 2003 Santa Fe so I used the same springs and now the left spring is rubbing the wall of the wheel well. Even used a new strut mount bearing.
Signed
Puzzled
Good day eh
You have to align the upper spring "pan" to the lower spring pan. If you take the strut out you'll see what I mean. It is not concentric.
The strut shaft will rotate to allow installation in any position.
I'm 100% sure because I did mine twice, but only once correctly. I thought I had defective strut bearings. But I was the defect!
