Mike, why you haven't tried to hook it up to the dash?Have the genuine accessory front sensors installed here in Australia. Well integrated with factory button on left of steering column to switch front and rear off or on. Also automatically switch off when travelling over 10 kmh as do the rear sensors and automatically switch on when gear lever placed in reverse.
Not hooked in to dashboard screen.
Beeps only but work as well as the rear sensors.
I suspect because it's an accessory and isn't designed to hook up to the dash display. If you were looking out the windscreen rather than at the dash display maybe you wouldn't need parking sensors anyway :laugh:Mike, why you haven't tried to hook it up to the dash?
I just string old tyres around mine when the missus is driving:laugh:husband must make sure it would be fully protected from damages! LOL
That is rather politically incorrect.Scottie, if car is gonne be driven by woman, husband must make sure it would be fully protected from damages! LOL
sorry, it was a joke, no intention to insult anybody.That is rather politically incorrect.
Thanks for the information. Actually I don't have the US style, not exactly sure which style it is...I think the top end model has the blind spot detection but I will have to check. Unfortunately, I am all thumbs when it comes to fine installation details - most likely will eff up cutting the holes in the wing mirrors or something and there isn't anyone down here with the necessary experience for that type of installation. I will probably just try to get the front sensors installed. My dash looks like the following when the rear sensors are activated. I am hoping that I can install the front sensors and maybe activate some settings on the module so that the front sensor inputs show up on the same car schematic. Will be very interested to see your installation semco.Yes, it is quite easy to do. If you have US style you should get not just parking sensors, but a complete blind spot detection sensors, like I did, so it will alert to you if there is anything in front you must notice about... Problem with the US style is that our lcd screen does not support front sensors (or it might but I don't know how to check it....). The EU style has a different screen and it costs some good $$$ which actually you can go for if you wish, but I prefer the simplest way without spending extra $$$ on replacing instrument cluster. I picked one which has extra display for that and will just install it on the top of the dash, it will look stylish and clean.I gonna do it in spring.
Hey Semco,Yes, it is quite easy to do. If you have US style you should get not just parking sensors, but a complete blind spot detection sensors, like I did, so it will alert to you if there is anything in front you must notice about... Problem with the US style is that our lcd screen does not support front sensors (or it might but I don't know how to check it....). The EU style has a different screen and it costs some good $$$ which actually you can go for if you wish, but I prefer the simplest way without spending extra $$$ on replacing instrument cluster. I picked one which has extra display for that and will just install it on the top of the dash, it will look stylish and clean.I gonna do it in spring.
That sounds completely sensible to me. It is a parking aid after all.When I asked the dealership they said only to turn them on when I am parking!
Just tried the links highlighted in the original post, none are now related to the post in question about Parking Sensors.Hey Semco,
I investigated further about adding in the front sensors. It looks like if you just have the rear sensors, it seems the brain module doesn't have the ability to add on the front sensors. Check the following link: Kia Sportage: Seat belts - Front passenger and rear seat 3-point system with combination locking retractor - Seat belt restraint system - Seat belts - Safety features of your vehicle - Kia Sportage SL Owners Manual.
If you wanted to add the front sensors, you would need to change out the brain module for the one that handles the smart parking assist - that has the connection to the front sensors. Check links:
(a) Kia Sportage: Instrument panel overview - Your vehicle at a glance - Kia Sportage SL Owners Manual
(b) Kia Sportage: Engine compartment - Your vehicle at a glance - Kia Sportage SL Owners Manual
I am not sure about the instrument cluster display if it can handle the new module. I suspect you would need to change it out as well. I think you may be right in the better way is to buy a separate system with a front display. I assume this is one just for the front sensors. I have ordered an 8 sensor system to be installed on my Tucson 2009 -
https://www.amazon.com/BeneGlow-Dua...22510&sr=8-1-fkmr1&keywords=Beneglow+8+sensor
If I have to install one for just the front, I may go with this one and just use the front sensors or a much simpler one. My only concern is having gotten used to the distance read out on the front sensors, I think I would want the same functionality on the rear sensors. So may check to see if I can use the factory sensors and hook in to the Beneglow unit or worse case, switch out the sensors.
Can you let me know which one you plan to use Semco?
Thanks.
Yeah, they used to work. Unfortunately the site removed all the manuals that was linked to Hyundai and put what you see there now. I was unable to find anything on the Hyundai manuals (the ones that I had found before) any more.Just tried the links highlighted in the original post, none are now related to the post in question about Parking Sensors.
