II don't know if there Is a posting on this already but I have a 06 sonata v6 with 100k and the front end squeaks like crazy. Sounds like possible coil spring problem. It happens more so in the cold. Sort of goes away when really hot n humid. Does anyone know about this and actually found the solution. Is it spring related or maybe bushing or upper strut mount??? Somebody has to know. . Thanks
Typical is the control arm bushing/bolts get all full of rust/road dirt.. then movement under load makes noise.
Take some ATF and mix it with PB Blaster, and use spray bottle to wet the upper bushings at control arms to body, leave it soak, and drive again..
Mix automatic transmission fluid with what?
