So about a month ago my 2013 Sonata GLS started to make some klunking noise going over the littlest bumps over the road from the front end on both right and left side.
I brought it to one mechanic and they said the rack and pinion needs replacing which is an expensive fix. I couldn't believe that was the problem as I had no leaks and it was on their solid. I ended up taking it to my uncles mechanic and he stated its the stabilizer links on the front right and front left wheels. My way to work has a lot of bad pot holes...thanks to our wasted tax dollars not fixing the roads year after year, so I'm hoping that the stabilizers are actually the problem.
Anyways, tomorrow I will be bringing it to the mechanic to have them both changed. I know a lot have been complaining about this issue and instead of replacing the rack and pinion, I thought I'd try and see if it actually is the stabilizer links and provide a fix for some of the sonata owners on here.
