Hi
I just replaced the bearing hub assembly in my Santa Fe 2007. i removed the assembly from the knuckle, there are four bolts holding it. Does anybody know the torque specs for this four bolts holding together the front knuckle and the wheel bearing assembly
Hi
Front Hub Specs attached.
Thanks for your help Wongpfh is the same for the Santa Fe limited with 3.3L motor do you have this additional information?
Thank you very much!!
