Hello all, new here. Just bought the wife a 2018 Santa Fe SE. Got it home and I was poking and prodding, trying to turn on the fogs. Come to find no switch and it's only on the upper levels. However, the lights appear to be there and so is the wiring and fuse. So my question is, can I just change the light switch assembly to get fogs? Does the PCU need to be flashed? Thanks for any help!
Do you have the owners manual?
00000732
* Do a seach for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
I do. Owners manual shows the switch but the switch in the vehicle is different from the one pictured.
Search yielded nothing of substance. I'll keep digging.
I'm wondering if the switch was replaced at some time with the wrong part.
Bought it brand new with 15 miles on it. Others on the lot were the same. I'd post a pic but site won't let me just yet.
Get hold of the dealer. I'm curious what they would tell you about the manual not matching the car.
  • Like
Reactions: Bootscraper
Discussion Starter #7
Mystery solved. What I thought were the fog lights are actually the DRL's. I thought the led strip under the headlights were the DRL's. We have no fogs. Thanks again.
