I have a sante fe 2013 sport. One of my front fog lights has a crack on it. The light itself works perfectly fine, the only issue is the glass covering is cracked.
Is there anywhere I can purchase a replacement for the cracked piece? I just need a new glass cover for it, not an entire replacement part. Searching online, I only could find replacements for the fog light assembly.
I don’t think I have ever seen a cover replacement for the fog light but rather the whole assembly, it would have to be heated with glue to be separated so it doesn’t make sense just to sell the cover. Can’t you look at some scrap yard to see if they have anything? Or another cheap alternative route is just use clear silicone and problem solved!!
