Hello,
With everything going on I am trying to save money by doing some maintianence myself. I can do the basics (oil change and filters). My question is what else is easily diy so I can avoid paying the mechanic upcharge. I checked my owners manual but it did not go into great detail regarding fluids in your vehicle.
My vehicle has about 75,000 miles. All that has been done since 26,000 miles are oil changes, filter changes, tires and brakes. have the following questions
Can/Should I change the powersteering, brake, transmission, coolant fluid? If so is there anything specific I need to know that is detrimental to changing out any of those fluids?
If so, do you flush those or drain and replace? I have heard that flushing is not recommended.
What heat # do you use for spark plugs?
Will replacing brake pads with "premium" pads make any difference, or should you also replace the rotors with the same quality to tell a difference?
What other tips or advice do you have for someone trying to save money on repairs/maintenance.
Any help is greatly appreciated!
