2013 Hyundai Sonata GLS
I purchased aftermarket jbl speakers and noticed that there is no bass in them really. Is that because of the factory radio? Should I just purchase an aftermarket radio?
What JBL speakers and mounted where? What year make model radio?
From what I can see, those are 2-way speakers and the reviews I can see, while they are clearer sound, don't have the bass that the OEM did across multiple vehicles.
So it could be they are under-powered or that they are just better with mids than bass.
I would make sure that the phase(+-wiring) is correct, and that the speakers are properly screwed and sealed snug up against the door. Double check the headunit bass/treble/fade/center....
It also takes 20-30hrs for a new speaker to loosen up and break-in, usually starting with low volumes and slowly moving up to more volume as time on them progresses. Biggest mistake that every yahoo does is cranking up brand new speakers all the way.
So, if you are not happy with their sound after 30hrs or 3 weeks of normal 5-day commuting, I would move them to the back doors and install a 6.75-7" speaker up front. Bigger speaker usually means more bass.
Yours:
https://www.jbl.com/car-speakers/GX602_.html
Mine, and am happy with their bass for the front doors:
XR-1800 XR-Series 7" Oversized Custom Fit Coaxial Speaker System | eXcelon | Car Entertainment | KENWOOD USA
The OE head unit has enough power for normal mildly loud listening levels. It will never give you braindead teenager thumpthumpthump garbage rave krap music they listen to these days. You'll need a subwoofer and amplifier for thump.
A small underseat sub will improve the bass for most, but they aren't big enough to share your noise with the neighbors.
https://us.banggood.com/Wholesale-W...-Active-Subwoofer-Speaker-wp-Usa-1213995.html
Another option is to upgrade the doors to 8" coaxials. Plastic door panels might need a little reinforcing in the back when cutting the hole a little bigger for larger 8" speakers. Flimsy plastic door panel for speakers!
Bigger options for the doors after you measure your depth and trim the ring on the door panel:
[ame]https://www.amazon.com/DLS-428-Reference-Coaxial-Speaker/dp/B00852Y150[/ame]
https://www.ebay.com/itm/FOCAL-210C...S-ACCESS-CAR-SPEAKERS-GRILLS-NEW/400581921332
https://www.ebay.com/itm/Renegade-R...ge-Car-Audio-Speaker-System-Pair/401556493357
https://www.ebay.com/itm/Blaupunkt-...cm-3way-Coaxial-260W-Performance/332380739268
https://www.ebay.com/itm/2-Cadence-...h-4-Way-Speaker-System-no-Grills/232839689929
[ame]https://www.amazon.com/Lanzar-VX830-8-Inch-Three-Way-Speakers/dp/B0007L8BBM[/ame]
