This is on a Hyundai Accent 2000, automatic transmission.
While replacing the driver's side front axle, a piece of what looks like a transmission seal, broke. Here's a picture:
You can see the whole where the axle goes, and this conical thing that is attached to the transmission. It had 5 bolts (I already took them out). But I have no idea if I can just jank it it out and replace it.
I went to the dealership with the photo, they say the part is not sold separately. Is part of an overhauling kit, part number "4501025A01", description "SEAL KIT-ATA OVERHAUL".
Therefore, my 2 questions:
1) Any idea where to get the part, or the kit, cheap?
2) How can I replace this?
Thanks in advance...
Your parts fella is an idiot--
I looked it up , and come up with 45331-28003 (differential side bearing retainer) @ a few cents short of $36... add for what appears to be an o-ring, and possibly the axle seal if it not already installed to the retainer.
You will likely need to remove the race and shim (if applicable) from old part and transfer to new part, and verify pre-load to differential...
