:) Hi all. Very new @ this stuff. Trying to remove heater fan moter from RH drive eXcel and have become stuck & run out of light and come in.
I wish to remove the fan motor as there is a knocking sound when the fan is run @ high speed so I guess some sound deadening material has been draw into the drum housing. Does any body have an efficent way of getting the motor out short of setting fire to the car?
Burrinjuck
Sorry mate, there is no easy way of removing the fan motor assembly.
I will tell you though that the rear screw that holds in the fan motor is the one you will have trouble with, essentially you will need a 90 degree ratchet screwdriver to get it out, otherwise you may damage the screw to the point where it may never come out at all.
The screw is located at the back and is usually hard to see because the carpet is in the way!
