The only comment I will make is that it is important to replace the radiator water glycol mix...I normally do a 50/50 mix, when you reinstall the radiator you will need to expel all of the air and also make sure the heater is fully open, squeeze the hoses with the radiator cap off until you are sure there are no more bubbles, top up the make up water tank with 50/50 mix also, I live in NZ and I use 50/50, just check the bottle for the recommended mix given you are living in a warmer climate...
