Could someone tell me what these sensors at the rear of the head are the new g4kd engine came out of an auto kia cerato and doesnt have them. old engine is siezed.
Discussion Starter #2
ok left rear of head is an oil control valve.
right rear is camshaft position sensor.
not sure if it what i should do now if i should swap the heads or will it run without these. the cerato engine is 2012 so and auto.
need the help of hyundai tech.
both sensors are very important. faulty oil control valve can cause timing chain and gear wear much faster, and without camshaft position sensor you can't run the engine at all.
If the both engines are the same gen same liters, I'm sure that they have the same sensors, maybe at different positions
