1 - 20 of 35 Posts
So my Motor is now dead, I am past the 120K warranty I need to know if the motor can be removed from the top with a cherry picker or is the only way to do it thru the bottom?
You should take it to the dealer, they have been replacing them beyond 120K! What can it hurt?
Tow to dealer, ask dealer to do "PA REQUEST" for replacement engine before you go goofing with it..... I take them out bottom with trans attached, though I remove lower bolts and torque converter bolts so I can simply remove top bolts and seperate
Got 1 out this afternoon, swap long block in morning, assemble exterior, and raise back into place
Son works at KIA dealer, I talked to 1 of the techs, he hoof it out top,, says he can have engine out in 45 minutes...
Mine blew up 2 weeks ago, dealer said if it’s obviously takin care of they will replace engine with 190k miles. But it’s when you don’t have any service records and there’s sludge packed in the engine they wont
I will check tomorrow, I did the recall and it was not one of the engines, I will drop an endoscope in it to look for sludge, I only ran Mobil 1 mostly highway miles changed the oil every 6K miles
They are all affected engines. Not a batch thing as far as anyone knows. The recall just tells you if engine is bad yet.
Sent from my ONEPLUS A5000 using Tapatalk
I know it sounds dumb, but clean out the car, wash it. Make it look like you really take care of it. Appearance goes along way I know if I was in charge of making decisions and somebody brought in their car that had so much brake dust on their front rims and it’s obvious They don’t give a crap about their car I wouldn’t pass it I’d say take it to a junkyard What if you tell me you absolutely love the car and it’s a shame that it had to happen they be sympathetic for you and try to help you out
Discussion Starter #9
Well I took it in they said they have to look at it to make sure that is seized then do the PA REQUEST Thanks sbr711 For that and see if Hyundai is going to cover it, when the ydo that they will then give me a loaner. So fingers crossed.
So, I should not buy my son a 2013 Sonata LTD with 99,000 miles? It is a one owner and has been siting on a lot for awhile, I suppose people are afraid of the engine failure issue? What is the link to check the vin? Thx
SO would you own ANY Hyundai, since you work on them? :)
  • Like
Reactions: grcauto
Aren't you glad most people don't feel like that? You'd be working at Honda....:laugh:
I far as I recall...he is a Toyota worshiper (not a bad thing) and makes more money fixing Hyundai's.
I tell folks I have a "Poor man's Toyota" and can't afford the real thing!
But I do like my car...it is a nice ride! :thumbsup:
They are a nice looking and nice driving car with a nice interior but I don't have a lot of confidence in my girlfriend's 2013. Especially with how fast the oil goes black on it.
I was Toyota from late 85 to mid 2002,, I still have my 89 Celica, fuel tank leaks bad, brake line popped last drive around block, along with P/S tube on rack' slave cylinder
19yr old son drives Ex' 93 Corolla 5 speeder
Nature of GDI,,, instructors at school refer to it as diesel with spark plugs,, fuel put into cyclinder on top of piston in similar fashion as diesel, and we use spark to light it off..
The super fine byproducts manage to get past rings to an extent and into oil
I suspect higher tension rings and regular oil change may slow it down
Sounds like a better reason to use synthetic diesel motor oil? :nerd:
1 - 20 of 35 Posts
