Please help what to do I was running 160kmph. When it reach 500kilo meter distance and check the oil in the morning the oil was below the dot of the oil metal stick.
Please help need advice
[snapback]2538[/snapback]​
did you check the oil before you started the trip ???
what model Sonata & what year ???
what is the odometer reading ???
what oil are you using ???
were are you located ???
did you check the oil before you started the trip ??? yes it was in the first dot
what model Sonata & what year ??? 1997 Sonata gl
what is the odometer reading ??? cannot remember
what oil are you using ??? castrol GTX
were are you located ??? KSA
[snapback]2809[/snapback]​
KSA ???? where is that????
yes Kingdom of Saudi Arabia... I was working here..... just asking why is that my oil engine are geting low if i run more than 160KM/hr.
