Can someone please help me in locating which part of the engine is the engine number located on a 2015 hyundai i20 se premium
On the kappa engines that are usually fitted to the i20 the engine number is stamped on the engine block at the gearbox flange above the starter motor. That's under the throttle body at the front of the engine.
Is it the numbers that are etched onto the metal area in the picture attached ?
No.
I have already told you where the engine number is. It's a complete pain the the arse to get at, but it is where it is.
Do you need to know the complete engine serial number for some reason? Or do you only need the engine code, which I can probably tell you if you tell me what engine the car is fitted with. Is it a 1.2, 1.4 or 1.6?
445570
