Here's a interesting problem, I had a noise like a loud squealing when it was really cold but today it was 40 and it was making the same noise but somewhat more quiet. This is a new alternator after the gasket oil leak which was done last year could this be another alternator going bad? The sound does go away after its been running for a few minutes. sorry sound file was too big to add.
Depends upon the squeak (which of course, we can't hear here!), but if you had oil down on the alternator, you may also have had some on the serpentine belt. Doesn't take much. Cold alone can do it, but add a little oil and ...
thanks the noise only started to happen when it was real cold and that was probably 9 months after the alternator was replaced, now it appears to happen after the car has been sitting all night and not as loud, I have the noise on a quicktime file so I will see what a dealer can make of it.
In my case, the squealing noise when it's very cold, 10~20ºF (= -12 ~ -7 ºC)
is fixed by replacing the power steering fluid to Valvoline Maxlife ATF.
Yes, it is Maxlife Dexron / Mercon ATF, which is synthetic base fluid I used also in my transmission.
I assume the squeal was coming from the serp belt due to high resistance when trying to turn the pump? Unusual solution. Belt should have no trouble turning the pump with stock fluid, even at those temperatures (which are pretty tame compared to what others see every winter).
PS pumps usually groan (not squeal) when they're unhappy about things like this.
I had the dealer look at it and let them here the video but they didnt see anything wrong and since it only happens when its real cold looks like I have to wait till next winter or something fails. Someone else has said it might be the idler pulley or tensioner pulley bearing as crime_sp said, is there any speific thing to watch out for when they fail? Like will it start making noise all the time or just fail and snap some belt?
idler pulley or tensioner pulley bearing, are they different parts since the Hyundai site is no longer available anyone have a diagram from the KIA site that shows both?
Usually, the pulley bearings aren't happy whether it's cold or not. Once the bearings go, you should probably still hear it. OTOH, a serp belt will definitely respond to cold.
Related Threads
Hyundai Forums
1.8M posts
410.8K members
Since 2004
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
