Over on the Gencoupe forum they made an engine leash to keep the engine from rolling on the motor mounts under hard acceleration. It does give some very good feedback. Doesn't make any P but sure does change the way it drives when pushing it.
Not needed. But it can be done to any car. I use to have a V8 fwd that I used a chain between the front exhaust manifold and the subframe. You will never have to worry about the motor mounts needing replaced.
I took the front one off. The lifting eye bent like a twizzler. The 1" square aluminum I got is too thick as the fuel rail interferes. I suppose I can machine the aluminum to fit but .........
From the length of the aluminum and only one bolt...it looks like you could pop that bolt? But I think the cable or ferrule would give-up 1st! :shades:
No slack on them so the engine doesn't get a lot of shock momentum. Just strain. But the back one has held up OK. It's got two studs it mounts to under the strut bar. The front one is a 8mm bolt. The block is 10 mm bolts.
A lot of people, me included, have to deal with the crappy manual trans they put in this car. Even the newer version with the carbon coated syncros still have problems; just not as bad.
But the problem is grinding in the upper gears especially when shifting fast. Another issue is notchy gear...
I bought my 2016 Genesis Coupe last October, and within a few weeks, I noticed that the climate control system was not functioning as I expected in maintaining the cabin temperature at a comfortable level. When I set the thermostat at LOW, I get cold (<40°F) air out of the vents as expected...
its a 2013 genesis coupe 3.8 GT
The drivers seat is stuck all the way back. it will move up and down and it will move back but it will not move forward. its my GF's car and shes 5' 2" so you can imagine its very uncomfortable for her to drive. i read the limiter switch will go bad and cause...
Hey everyone,
(Sorry I’m advance for the long post)
I have a 2014 genesis coup 2.0t rpec with ~70k miles. Recently I hit a decently sized pothole with my right front tire (city roads are the best). Due to this I knew my alignment would be out, but began hearing a squeaking sound every time the...
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
