Engine jerks at low RPM about 1000-2000rpm and then picks up speed fine. but sometimes while at high speeds i find it picks up speed after a while (suddenly). i recently had timing belt kit changed but the dealer says it can be the plugs or the fuel filter not because of the timing belt, i recently bought this and i am not sure if the Fuel filter or the plugs were ever changed. its done 132,000kms now. any idea what can cause the jerking?? Thanks
Is the check engine light on? Any abnormal dash lights? It's tough to diagnose if it comes & goes without setting a code. The fuel filter is built into the sending unit on these. Spark plug replacement is also a pain because the intake manifold has to be removed to get at the rear bank of plugs.
Joel
no check lights on or any other abnormal lights on. the mech said it looks like a coil is dead on the plug. they will open up tmrw to check it.
