OK here it is. The Engine Damper from KFXperformance. I'd rate this add-on a must have 8 out of 10, the install was on a 2007 Accent SR. It has the DCsports Strut bar and AC. Some modification is needed.
1. You will need a longer screw and washer to mount the front bracket.
2. You'll need to cut out a section fo the DCsport strutbar.
[attachmentid=8763][attachmentid=8764]
