Hi guys i have a 2003 accent with D3EA engine and im having some issues with the engine. It has loud ticking noise when accelerating especially on uphills. Tappets changed because had some faulty ones. Im thinking of the injectors or else the balancer shaft.
Anyone had this problem before?
The battery is good at aboit 85% had new cable to battery terminals tightened and one replaced. Thinking connection was bad with corrosion .That did not solve problem. Over last 2 days there was intermittent problem of NO CRANK, and No turnover , did start after awhile .
But now no solenoid...
I'm a Pilipino mechanic I have a problem the original crankshaft was broken the machine chains a new after the I assemble the engine all timing mark seted then I put the engine to unit and all electrical socket connected put battery everything completed every erference voltage is ok all sensor...
I recently replaced a purge solenoid in a friend's 2008 accent because of an issue starting after filling the fuel tank. Removing the solenoid showed a bad seal- I could blow through it in both directions with no power applied. The new solenoid definitely works as intended. However...
I did not...
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
