2002 2.7L Automatic Santa Fe. The 120 Amp fuse keeps burning. The unusual part is there was a 50 amp fuse in there when this problem occurred. So I figured someone messed up and put the wrong fuse in. I replaced it with a 120 amp fused and it still burned. Also the instrument lights don't work. Any suggestions?
How long does it take for the 120A fuse to blow/burn?
Instrument lights inop, are you talking about the illumination of the instrument cluster, switches, etc? If so the first thing to check is the two tail light fuses...
