Engine Check Po 715 And Po 705 Codes
3464 Views 1 Reply 2 Participants Last post by  Trev0523
FOR THE LAST 3 MONTHS I'VE BEEN DRIVING AND I'LL NOTICE AN ENGINE CHECK. THINKING IT WAS MAYBE A FILL UP CAP TWIST PROBLEM. BUT FOR THE LAST TWO MONTHS I'VE NOTICE WHEN I RECEIVE AN ENGINE CHECK I NOTICE THAT MY RMPS ARE HIGH FOR THE SPEED I'M GOING. BUT LATELY I WAS LEAKING TRANSMISSION FLUID. THE SEAL WAS REPLACED WHERE THE AXLE GOES INTO THE TRANSMISSION. BUT STILL I'M GETTING AN ENGINE CHECK. NOW THE ENGINE CHECKS MORE OFTEN. AND WHEN IT CHECKS THERE IS A LURCH. THIS CHECK HAPPENS 3 TIMES A WEEK. TURN OF THE ENGINE AND DRIVE AGAIN AND IT’S FINE.
I HAD THE ENGINE CHECK INTERPRETED. AND HERE IT IS:
P1525 MANUFACTURE SPECIFIC
PO715 INPUT SPEED SENSOR
PO705 TRANSMISSION RANGE SENSOR CIRCUIT
MY TRANSMISSION FLUID IS CLEAN. NO BLACKENED AREAS AT ALL.
SHOULD I BUY WARENTY PROTECTON? WHAT WOULD A HYUNDAI SERVICE CHARGE? or even better I read in another post that the input or output speed sensor(are they the same sensor?) can be found under air filter and costs fron 70-100. Anybody have the cost of the range sensor or where its located and how to work with it ?
Thanks
The Input and Output sensors are in fact 2 different parts, both located on top of the transmission. There is a DIY for it on this site. FourGreen.com sells the parts for about $37 ea. If you replace one, you should probably replace the other even if it hasn't come up on the CEL yet.
As for the range sensor, its probably connected to the input code. Try replacing the input/output first and see if it fixes it. I had P0708 (TR Switch) come up when my sensor failed but just replacing the input/output fixed that problem to. Tranny shifts like its a brand new car again.
It's a process of elimination, you should notice that new input/output sensors fix that lurching problem right away and go from there.
Hope this helps
