1 - 20 of 23 Posts
Hi all,
This is my first post - I took delivery of my i20 1.6L on Friday (in South Africa).
RDS does not seem to be automatically enabled. I wanted to find out if it is available on South African i20s, and if so, how do I enable it?
QUOTE (Joe Talin @ Jul 4 2010, 07:40 PM) index.php?act=findpost&pid=338790
Hi all,
Hi and :00000732: to the forums. It should explain in your owners handbook about RDS if equipped....... but, i just looked on Hyundai service site, and your audio may not have RDS!
QUOTE (jsinton @ Jul 4 2010, 08:12 PM) index.php?act=findpost&pid=338796
What's an RDS?
Radio Data System
See the Wiki ste for more info http://en.wikipedia.org/wiki/Radio_Data_System
QUOTE (Mr Pogle @ Jul 4 2010, 07:18 PM) index.php?act=findpost&pid=338842
Radio Data System
Hi Mr P,
My owner's handbook states "*if equipped" for most features (my car has many of these). The handbook is the one printed for Hyundai India, or so it says in the printing information.
The manual mentions RDS under instructions for the <SETUP> button, but doesn't elaborate at all.
QUOTE (BMN @ Jul 5 2010, 09:26 PM) index.php?act=findpost&pid=339013
Try this:
Turn on the radio and then turn off.
Press 1 and 6, both at the same time. Firmware version will appear.
Then pressing keys 1 to 6 will show hidden menus.
The key 4 is RDS parameters.
Hi BMN
I tried what you suggested. After pressing 1 and 6 together, the firmware version appeared (see photo).
However no amount of pressing 1 to 6 (including 4) showed any hidden menus.
After a while, the firmware version disappeared again.
Is there perhaps another way to view the hidden menus?
QUOTE (BMN @ Jul 5 2010, 09:18 PM) index.php?act=findpost&pid=339030
I think all models have the same radio.
Not sure about this as I found these differences.
Red circled would be for European market......
Note the different labelling of buttons between European market and General market models
So it appears that there are 2 models of head unit PA710R for Europe with RDS, and PA710 for General market without RDS
Hope this helps.
Discussion Starter · #9 ·
QUOTE (Mr Pogle @ Jul 6 2010, 10:36 PM) index.php?act=findpost&pid=339305
Hope this helps.
Where can I get that manual from which these screen shots are taken? wow!
I will check my car a bit later and let you know which version of the radio I have
Discussion Starter · #11 ·
QUOTE (Mr Pogle @ Jul 7 2010, 10:34 AM) index.php?act=findpost&pid=339445
sign up here http://service.hyundai-motor.com/ If I recall, you need to disable your pop-up blocker whilst joining...... I think!
I'm feeling a bit stupid here...
I managed to create an account and login. I browse to the correct vehicle year, model etc but I don't seem to be able to display that manual.
What should I be clicking?
QUOTE (BMN @ Jul 7 2010, 11:17 PM) index.php?act=findpost&pid=339646
Good photos BMN :thumbsup: ........... now I see what you're saying, but the fact that, as you point out for example, you can switch bluetooth on and off and yet it still doesn't work leads me to believe that there are internal hardware differences between the 2 radio models even though both models use the same firmware. And if this is not the case, why the different labelling of the buttons, TA and PTY are specific to RDS functionality only?
Discussion Starter · #14 ·
QUOTE (Mr Pogle @ Jul 8 2010, 06:54 AM) index.php?act=findpost&pid=339716
I have the non-European radio :-(
I have the MUTE button instead of the TA button.
I guess no RDS for me.
Though it does seem to be a silly thing to not have in a modern car radio.
Thanks for the step-by-step in the Shop Manual! I was trying to use Firefox - that didn't work at all. Internet Explorer was, unfortunately, the way to go
QUOTE (Mr Pogle @ Jul 7 2010, 09:34 AM) index.php?act=findpost&pid=339445
Sorry, a bit off topic but ... Do you happen to know if the access charge of €5 per hour is for a single whole hour or part off, ie, if you disconnect after say 45mn and realise you forgot to look something up, do you need to pay a further €5 or would you still have 15mn 'credit' ?
QUOTE (BGRT @ Jul 10 2010, 05:10 PM) index.php?act=findpost&pid=340535
By using Internet Explorer (it doesn't like Firefox) and turning on (or off, can't remember which way round) your pop-up blocker......... you don't get the charges box appearing :thumbsup:
If it doesn't work with pop-ups disabled, try it the other way LOL
QUOTE (Mr Pogle @ Jul 10 2010, 07:05 PM) index.php?act=findpost&pid=340572
Cheers, pop-up blocker ON does the business... neat trick thanks !
QUOTE (Joe Talin @ Jul 8 2010, 01:17 PM) index.php?act=findpost&pid=339739
DONT WORRY ABOUT IT ... SIMPLY CHANGE THE AREA IN THE HIDDEN MENU TO EUROPE OR EUROBT..... U WILL GET ALL THE FEATURES AS IN EUROPEAN MODEL LIKE RDS , TA etc.... ..... EVEN BLUETOOTH MENU ALSO..... I THNK BLUETOOTH HARDWARE OR DONGLE IS NOT THERE IN THE HEAD UNIT so it will not work.
1 - 20 of 23 Posts
