Does this mean that I have a head gasket gone or a warped head.
Does anyone else have the same problem? If so tell me about it please.
Other than this we are very happy with our 2000 Grandeur
Ok...
I Did not understand you....
But...
In my car, there was a slight leakage around the oil filter...which was first due to the mechanics that changed the filter,,, then after a very long time of driving
(220 000KM) it was a little bit more due to the gasket...
so repaired that and everything is OK now.
wish you good times.
If you are seeing a whitish sludge on your oil cap - yes its very possible coolant is getting in the oil somehow, possibly a blown head gasket.
Have a pressure test done on the cooling system and an engine compression test -if there is a leak it would likely show up through one or both.
