My car a santa fe year 2004 diesel cranks but doesn't start changed the camshaft sensor twice but still showing same error.looking for a 39101-27202 ECU anybody can please help me
Its showing that camshaft sensor is not functioning properly every time even if it's a new one
OK, so the ECU is not happy with the cam sensor signal. That doesn't mean the cam sensor or the ECU are faulty. The sensor is cheap so it's sometimes worth just replacing it to see what happens. But you'd be a fool to take that approach with an expensive ECU.
There are several things that can cause a cam sensor code. Have you checked the voltages on the sensor connector yet to make sure the wiring is OK? Does the sensor have a good 12V power supply? Does it have a good ground, and is there 5V on the signal terminal? You'd definitely want to do that before replacing the ECU. The other thing you should check is the timing belt. If the cam shaft isn't turning that will cause a cam sensor trouble code. Again, replacing the expensive ECU isn't going to fix that.
CAM SENSOR VOLTAGE TESTS
