Hello,
2014 Elantra GT began making noise under the dash at the ventilation air box. Turn on ignition key, sound maybe linkage to an air door? Happens every time I start the car, temperature is not a factor. Duration 1-3 seconds.
Quick inspection under dash - nothing visible. Inspected the cabin blower assembly, cabin air filter - not problems.
Does anyone else have noise problems under the dash, in vicinity of the ventilation air box? Solutions??
00000732
Do you have the auto temperature control system? The auto system will start the blower off on your feet for about 2 seconds when you first turn on the battery/engine, then rotate to whatever airflow direction you have selected.
