Hi All,
I've a wired problem, my Elantra 2008 gas pedal is being stuck on the first push down only, when the car parked for more than 3 hours for example, the first press on the pedal i feel it very hard then it accept the pushing with a sound as if something is stuck and got released, after the first push it become very normal till i park it again.
i greased the pedal but noticed it may be the throttle cylinder at the engine where the gas wire is going around, i tried to accelerate the engine by turning this cylinder and it is being stuck at the first then is loosen, i tried it spray it with WD40 but it is the same.
appreciate your advise.
