hi guys
had to replace the egr valve but for the life of me can't remember which hose goes where , does the hose from the actuator go to the egr valve or is it the other way around
I do not understand the question, the other way around??
When you do it the wrong way you will notice a rough, bad idle.
When correct you will notice a smooth idling engine.
Also, the EGR valve normally should kick in at about 2000 rpm.
Good luck,
Paul
