It'll look something like this :Any one had a pic for Ecu accent 2007 automatic with maf sensor
Actually, they wont. They will give him the part number of the original manual transmission ECU since that was what was fitted when the car left the Hyundai factory.Ask your local Hyundai dealer, type in your VIN and they can tell you the part number of your ECU.
You could try linking the output of the VSS to the ABS speed signal wire. I think it's electrically the same type of signal although I doubt the signal frequencies are the same. Still, that might at least get rid of the P0501 trouble code which I assume is being logged.if any one can help
You'd need a frequency multiplier circuit to increase the VSS signal frequency. There are dedicated ICs for that purpose but I used an arduino micro controller for a similar project just because I had one to hand. You can adjust the input : output ratio in software if using the arduino which makes adjustment really easy.any one can help adjusting
