Hi all, I installed battery with wrong terminal (Positive side of the battery to Negative side) and now engine of my car accent 2004 is not starting even after changing the battery to right place? any body can help to solve this problem?
DVOM and test each side of every fuse/fuse link... reverse polarity will pop any active fuses, including them 60/80/100+ links there in the cable and fuse box.. find them and get power progressivle back to normal.
QUOTE (G.H.Mughal @ Sep 11 2010, 06:31 PM) index.php?act=findpost&pid=355733
Onle one fuse 120Amp was burnt out I replaced still the problem is the same
Keep going, test each side of each fuse in the engine compartment, and the passenger compartment...
