:liebe011: :liebe011: I have a problem with me ECU I beleive.
My Tuscon drives along no bother then for no reason the malfunction indicator light warning light comes on this is not to much of a problem until the 4WD system warning light comes on then I lose all accelorator power although the engine stays running in idle, I can limp along slowly.
When I turn the engine off the horn beeps once.
Then after a little while and a few turn on and offs of the egnition the lights extinguish and everything seems to be normal.
Then all of a sudden it happens again with no real pattern.
I can go along for weeks at a time then bang for a week I have this intermittant problem.
I noted if the horn does not beep after the engine is turned off then when I next start the car up everything is fine.
Someone told me that sometimes the ECU may have a loose connection something to do with three wires and one working loose may need to be re-soldered.
Could this be the problem, if so can anyone out there tell me where I would find the ECU in my Tucson.
Any help would be gladly accepted.
Kindest Reghards
HMacD
Kindest Reghards
HMacD
