hey, i own a 2002 hundai sonata 2.4, It blew the ecu fuse twice so i changed the fuses, and now i have no spark at all.. I changed the coil packs, brand new, spark plugs, crank, cam, ignition failure sensor and a ecu. and still no start. Fuel pump is running fine.. When i checked the wires going to the ignition coil packs, one is geting power, the other is ground, and there is one more wire that is dead. ( is it supose to be dead or have power running throught it.. I dont know what else to do anymore.. I did check all the fuses and relays, everything is working, but still no spark... Anyone? please? i even replaced this gold box that is located under the radio... is there another computer somewhere? i only found two computers in the vehicle.. Under center console dash, by the firewall.. there is one with 4 black plug connectors and one with one 2 inch that is connected to the airbag computer.. I dont know what else to check or do.. is there anymore computers or relays that im missing? I have the whole dash taken apart so every wire is visible..I know that every pink wire is connected to the ignition system. please some one help me..
