I installed a set of bi-Xenon HIDS identical to these
in my wife's 2008 Accent. I unplugged the DRL module as shown in a thread I found here, but now there's no high beam indicator on the dash. Is there a wire on the plug that I can put a jumper on or something to make this work again?
And before all the nay-sayers growl at me, instead of assisting with this problem, I aimed the lights really low so there's minimal glare to oncoming traffic. We drove about 125 km last night with them and never got high-beamed once.
The Fords are like that.
The Hi beam indicator going to the IP is wire #2 on the DRL module plug. You will have to jumper that to the hi beam signal. Looks like a power wire. Did you try to just unplug the DRL resistor?
I simply unplugged the drl module below the battery...
