Hi! I'm trying to solve an issue with my 2007 Accent GS Hatchback 2D. The driver's door lock won't lock from a keyfob or a door lock button. It works perfectly fine when I actually use the key or when I manually press the door handle switch. Unlocking works well. Other doors work with no problems. At first, it was an intermittent issue (I had to press a keyfob button multiple times to make it lock) but now it's completely dead.
Changed the battery in the keyfob - no luck. Changed the fuse in the fusebox - no luck. Changed the actuator - tested it from the keyfob and it worked (yay!) BUT when I assembled the door back together it stopped locking again! ?
What's inside that door that might've gone wrong? Any tips?
