Hi all, have been trying to track this fault for days, light works on all other doors except the drivers, have swapped the passenger switch to drivers side and probed the loom under the fuse box on the floor and I'm getting 6.53volts but the light isn't working even if I short these out, has anyone else had this problem. Or know how to solve it? Cheers in advance.
00000732
* Do a seach for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
Oops, OK, it's a 1997 Hyundai excel X3 sedan, 1.5litre sohc. Only new here so all advice taken.
Does your car have a door ajar warning chime, or a lights on warning chime? If so, does the chime sound switch on & off when you open & close the drivers door with the ignition or the headlights on?
Hi auto spark, it doesn't, it's standard wiring to all four doors, it's only the drivers side not working, the wiring is reading less than 12v and I'm assuming it should be, all other doors work I know the drivers side switch works it's just not coming on, I don't know if this is a common issue with these cars, it just seems weird.
Is the wiring on the driver's door switch the same colour as the other door switches?
The driver's door switch is usually used for controlling the warning chime so it isn't directly connected to the courtesy light circuit, unlike all the other door switches. There is usually a blocking diode between the driver's door switch and the courtesy light circuit to prevent any of the other doors from setting the chime off. I know your car doesn't have the chime sounder but maybe it's still wired up with the diode. If the diode was open circuit that would prevent the driver's door switch from operating the courtesy light. Unfortunately, Hyundai don't tell you where the diode is. They are usually just taped onto the loom somewhere (with yellow tape to make them visible). I'd guess probably behind the footwell trim or behind the dash at the bottom of the 'A' pillar.
Discussion Starter #7
Auto spark, cheers for that, will do a search and see if I can find it, I've got other wiring to put in so while I've got the carpet up and dash apart it will be the perfect time to locate it and replace it, cheers again.
