Remove door panel
disconnect galss from lift
raise glass up off lift ears and use long strip masking tape to hold glass up
remove 3 latch screw
remove exterior door handle
remove screw holding handle frame to door, and pop frame off door
remove bolts aruond perimeter of regulator panel
remove panel with latch attached,,, pay attention as you will need to unplug connector from latch, and fart with wiring at front of panel to allow panel to come off door shell,, you can swap latch from there,, I do them by myself
