1 - 1 of 1 Posts
Hi all!
My driver's door isn't closing tightly so as I'm driving at speeds it makes an annoying whistling noise, and it's directly in my ear!
It's not letting in any water so it's not that bad but if you see from the photos you can see that the door isn't lined up correctly. I'm not too sure how long this has been like this but it's only quite recently gotten worse.
Is there any way to adjust it? I've loosened the door jam and seeing if that moves but it doesn't seem to want to move at all so is there another way? I'm going to get some thick self-adhesive weatherstrip to see if that helps for the time being as I might even need to adjust the actual door itself.
1 - 1 of 1 Posts
