Devils own job trying to get the 32mm drive shaft nut to un do.
Have an extended breaker bar. No joy.
May try heat tomorrow.
Any one else expereince the same issue?
Thanks, :frown:
I just took the drive shaft out of my Gen Coupe to put in new flex disc. I don't know if your has such a set up. But the nuts you take off from both ends are reverse threaded. The heads, which face towards the trans or diff, have a concave head which you can feel but cannot see.
Some years ago I change the outer rubber bellows on the drive shafts in our 2006 Getz 1,1. The nuts was not a problem and I do not remember, that the threads was left turned. But of course that would explain your problems. You better check which way to turn the nuts.
