Hi new member here,
Only had car few weeks its, Tucson limited crd 2007 61000miles, problem is em light on ,attached scanner low rengeration in dpf filter ,took it for long run 70miles at 4000rpm attached scanner again cleared codes ,light out for 10mins then back on wondered if anyone had similar prob and knows quick fix ,also egr valve is it a good idea to strip this out and give it a clean to prevent problems occurring due to clogging was a old guy I bought car from a very rarely drove over 30mph .
Thanks guys any tips welcome Dougie:00000732:
Thank you.
Was hoping for more replies guys, cant be only one to ever had these problems,,dpf and egr common fault items,, all tips welcome.
I've had this problem on my Tucson.
But some EGR cleaning spray from your local motorfactors and spray it in to the air intake while the engine is running (follow instructions).
A good clean should keep you going for at least another 6 months, then you can spray it again.
