1 - 1 of 1 Posts
I have a 2013 Santa Fe and recently started using it to pull a small camper trailer. Most times when I hook up the trailer the DBC light illuminates yellow and stays on until I turn off the ignition. Trailer has electric brakes with a brake controller.
I don't care about DBC. I would never need or want to use DBC so don't care if it doesn't work but I wonder if there could be some other underlying issue? Brakes work fine with or without the trailer connected. Is there any reason to be concerned?
1 - 1 of 1 Posts
