1 - 1 of 1 Posts
I'm going crazy! The door sensor in my 2009 Elantra i30 thinks the door is open when it isn't. It's running the battery down because the little display that shows when a door is open is always on.
If you push on the door when it is closed you can get the sensor to register the car door as closed, and adding a fair bit of tape to thicken the post the door closes on can get it to go off, but only with a lot of effort because the moment it closes, the door slices into the tape and pulls it off of where it needs to be.
What can I do? Is there an easy fix or hack? Can I pull a fuse and get the display stay off? All I really need is to stop that **** power drain.
THANKS!
1 - 1 of 1 Posts
