When I lock the car using either the remote or using the button on the driver side, all the doors lock properly except the Driver Side lock which does not turn. I am assuming that the motor is worn out. any help in this?
2004 4DR GLS Sante Fe 2.7L V6.
Replace door latch/actuator assembly, however the actuator is sold.
QUOTE (ssruindia @ Aug 12 2010, 12:59 PM) index.php?act=findpost&pid=348952
Thanks for the Quick Response. Is there a Flow Diagram to see how to remove the door parts and get to the Actuator?
Go to hmaservice.com and sign up...
Just take the door panel off, and work your way in to remove the latch/actuator..
