Hi everyone
When I got home today and went to push the button to lock my Tucson 2016, there was no button at all. Is this covered under warranty. It is really easy to replace the whole handle. I can't seem to find only the button part. The car has 41k miles.
Thanks in advance
Probably warranty, depending on the general coverage in your country. And there may exist an aftermarket button solution but odds are it's the whole handle assembly. Exterior door handles are annoying, door trim has to come out, window regulator subframe assembly if applicable, sometimes there are big enough holes in the door frame itself to get hands and tools in.
Thanks for your answer. I went ahead and ordered the handle assembly. I watched a youtube video and is really straight forward to replace it.
We'll see.
The 2016 and up door handles are ridiculously easy to remove and install.
On the inside of the door there is a black cap covering a screw.
Remove the screw pull the keyhole section off and slide the handle(to the right for driver).
Look for the door handle on ebay.
If it's covered under warranty get it done but it's not too expensive to do yourself.
