you know those LED door catches that always pop up on Sonata accessory searches? I knew I wasn't taking off my door panel to wire these, but what if I can just install them because of the glossy look and writing. I got them for around $27, so figure not THAT much of a risk.
Anyway, I love them, A little detail but something that catches the eye all the time. Basically the "guts" of it is just a piece of plastic glued on the backing with the wires, and you snap them right off. Then it's literally just the black plate. Get some thick double sided tape, and they go right on top of the existing OEM plastic door catch. Once you remove the back wiring, you'll reveal the writing to be clear, but ends up matching the handle color once you put it in.
Apparently they also have stainless, and without the "LF" moniker as well.
looks like they do, remember the cheaper the better! lol.
Unless you actually want to wire them. But even if I had the ability, I'd most definitely leave it as is. It really does look stock, the LED would be to garish IMO
