Looking for insight on the soft close function on my 2014 Equus Ultimate. My driver door is not soft closing now. No issues before it simply stopped working on driver door. Still opens and closes fine with no issue. Checked fuses, all good, so I found new door latch assembly with the auto close motor assembly included and replaced it with no luck. I don’t have a wiring diagram so not sure where the voltage paths are, but assuming I may have some faulty switch elsewhere the signal may pass through. Any one with experience on signal flow on this to direct me to probable culprit?
Check the wiring in the loom that passes between the pillar and the door.
