After replacing front sway bar links I can always hear squeaking noise when the front wheels move up and down. It sounds like bad upper control arm bushing. Then I found this. Moog sway bar links have grease fittings that get too close to the car body and rubbing the metal. Now I replaced them with LEMFÖRDER links and problem solved.
For NF sonata users don't buy Moog front SBL(front only, the rear ones looks fine) or any other brands with grease fittings. Make sure there are nuts designed into the bolts and deep enough, so you can prevent the bolts spinning when you tightening/loosening the nut
