1 - 14 of 14 Posts
Hi
Can anyone help me please?????
My Lantra (1995-96) 1.6gls is refusing to start although it is turning over, it's almost like there's no fuel although the tank is full. Does anyone know if there is a fuel safety switch fitted on this model, if so where is it located.
Thanks in advance for any help given
bee1711
Originally posted by bee1711@Nov 18 2004, 06:34 AM
Hi
bee1711
[snapback]2862[/snapback]​
:eek:
Sure there is not a switch to fuel supply.
Make your fuel and ignition system to be checked.
Sure the problem will be otherwhere.
Regards
Selenico 77
Hi
bee1711
I add.
Surely not Factory released.
I don´'t know if there is an adaptation afterwards
Regards Selenico77
Originally posted by duke@Nov 18 2004, 06:09 PM
check if there is spark at the plugs, and let me know.
[snapback]2875[/snapback]​
Hi Duke
Yes there is spark at the plugs!.......
Thanks
Bee1711
put your hand on the fuel line at the engine, have someone start the engine, can you feel the fuel pulsing through the line ???
Discussion Starter #7
[snapback]2931[/snapback]​
Hi
Yes you can feel the fuel getting through
Cheers
Bee 1711
Originally posted by bee1711@Nov 20 2004, 08:41 AM
Hi
Cheers
Bee 1711
[snapback]2935[/snapback]​
At this Stage of the Diagnostic, I expect the trouble is at the Ignition-Fuel
System.
Tell me is it inyeccion fuel or Carburator?
Selenico 77
Discussion Starter #10
Originally posted by duke@Nov 20 2004, 08:49 PM
OK, now it is very important, WHAT MODEL YEAR is your car 95 or 96 ??????????
[snapback]2942[/snapback]​
Hi
Thanks for your help!
It is a 1.6gls 1996 fuel injection....
thanks again
it's a 1996, an RD with an ACCENT engine i think; here in north america, it has the 1.8 & 2.0 ltr beta engine.
So, it got spark & fuel, ............... then the engine MUST start.
If the valve time & ignition time & compression is ok, then the engine must start.
How many km's did the car do ?? Was the timing belt replaced yet ????
Discussion Starter #12
[snapback]2985[/snapback]​
It's done 66000 miles and the belt was changed at 50000 miles
Cheers
Bee1711
difficult to do anything from afar, I strongly suggest, that a HYUNDAI tech has a look at it.
If there is spark & fuel, then someting else is amiss; could be fuel pressure - injection amount - compression - valve time ..........
1 - 14 of 14 Posts
