2011 Sonata GLS
Does the oem donut spare tire have the pressure sensor in it to alert low pressure on dash?
Tire pressure light came on briefly while driving, was flashing and then went off. All four tires were at 35psi when I checked after 1 hour cool off. Donut spare only had 30psi, should be 60psi.
No idea what set off dash tire light. Outside temp was upper 60's, maybe 70°F.
It does not and will not trigger the light. One or several of your sensors may be running low on battery. Mine does that once in a while and self clears. As long as it goes away, there is still life in them. Also, sometimes it gets triggered by interference from other devices.
Assuming your light flashes steadily then stays lit for a bit before going off, right?
