I like to think I am pretty good with a wrench. I have a decent understanding of cars and can make my way around an engine bay fairly well.
But for the life of me, I can't find the Vapor Canister Purge Valve in my 2014 Sonata Hybrid.
A little backstory:
The car's CEL came on. Ran my scanner, found it to be a P0456 code. Reseated the filler cap, cleared the code, and drove for a bit. The light came back on.
So, I bought a new OEM cap, replaced the old one, cleared the code. Same issue.
After a little digging, I found that it could be the Vapor Canister Purge Valve. Bought one from a parts store, basically this: Part
I spent a good part of yesterday looking through the engine bay trying to find it, with no luck.
So what gives? Did I buy the wrong part or am I just blind?
Discussion Starter · #2 ·
Ignore me. It's literally to the right of the engine in plain sight. Just follow the evap lines.
FYI for anyone reading this in the future, the part I listed won't fit. You'll need something closer to this: Part
Good to hear JKK! Makes me feel better.
Considering that I can't quite confirm that this is what's causing the fault and I bought the wrong part, I am just going to bring it to the shop.
I recently replaced the purge solenoid valve on my 2016 elantra. I tested the valve [off the car] before replacing it and I was surprised how small the leak was. It took 15 seconds to drop from a vaccum of 20" of mercury to zero but I replaced it anyways and the code was gone.
Do you have a suggestion on a vacuum tester?
